#1 13-07-2019 22:27:57
Maxipes
Registrovaný: 13-07-2019
Ahoj,je to dobrá kukla ?Nebo poradíte lepší do 1500 Kč ?
kukla Proteco P800E   https://www.prijemny-dum.cz/proteco-kuk … gLHiPD_BwE
Editoval Maxipes (13-07-2019 22:35:24)
#2 13-07-2019 22:49:51
Re: Ahoj,je to dobrá kukla ?Nebo poradíte lepší do 1500 Kč ?
cim lepsia kukla, tym viac jedniciek - plati rovnake pravidlo, ako pri adidase - cim viac pruzkov, ..... idealne, ked sa s nou mozes pomazlit, vytunit, vylepsit, vytlacit na 3D tlaciarni nejake stlpiky - proste k nej ziskas nejaky citovy vztah a uz nebudes chciet inu ...........
http://www.svarforum.cz/forum/viewtopic … 95#p142795
pripadne nieco pre "sikme" ocko - cinan ti da styri jednicky 1/1/1/1 aj na flasku od piva, kua este aj zabalene v americkej zastave, ze aj chuck norris by zavidel.....
€ 51,77  40%OFF | Welding Mask Best Optical Quality 1/1/1/1 Big View 100*73MM 3.94*2.87" Respirator Safety Hat Compatible CE Solar Welding Helmet
https://s.click.aliexpress.com/e/cXAJGOwy
€ 50,29  40%OFF | Welding Mask Best Optical Quality 1/1/1/1 Big View 3.94x2.56" 100x65mm Widest Shade Range DIN(3)4-13 CE Solar Welding Helmet
https://s.click.aliexpress.com/e/5FoMu8C
€ 46,28  30%OFF | Welding Mask Top Class 1/1/1/1 View 100*65mm(3.94*2.56") Shade 3(4)/4-8/9-13 Solar 4 Sensors Carbon Fiber Welding Helmet EN379
https://s.click.aliexpress.com/e/c3LOJkMo
€ 19,40  26%OFF | Aldismala Welding Helmet Best Optical Quality 1/1/1/1 Big View Size 96x48mm Welding Mask Head-mounted automatic Adjustable mask
https://s.click.aliexpress.com/e/c0fgeCOy
https://www.youtube.com/watch?v=k3DQ0-u_B4A
https://www.youtube.com/watch?v=EfEXEcO97Hs
https://www.youtube.com/watch?v=0ULwHF74_1w
https://www.youtube.com/watch?v=c1FUBkzf2fc
Ps: chuck udajne zvladne PF-ku aj na padaka celulozovou elektrodou .....
Editoval rcp (13-07-2019 23:07:35)
